why does radio point down on fuse block?
Old Aug 14, 2019 | 10:20 PM
LiquidBlue's Avatar
Car: 90 Formula / T-tops
Transmission: MD8
can anyone explain why the radio arrows seem to point the wrong way?
Old Aug 15, 2019 | 01:26 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: why does radio point down on fuse block?
Looks right to me...
Old Aug 15, 2019 | 09:01 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
The arrow is pointing to the terminal below the radio fuse, which I am thinking is just another available connection to the radio circuit so you can connect something else on the "accessory" switch position. For instance, a turn on wire for an amp so it is only on when the ignition switch is in accessory, or run
If you look at the diagram to the right you can see the back side of the fuse panel where there are also more connections for ignition, hot and accessory (radio), and I think the front terminal is just an extension of the rear connections, for people that want a quick and dirty way to connect more circuits in the car
Old Aug 15, 2019 | 12:00 PM
LiquidBlue's Avatar
Transmission: MD8
ah ha, that makes sense. I'll bet your are correct sir!
Old Aug 15, 2019 | 07:52 PM
JT's Avatar
JT
Community Administrator
Agree with scooter. The 1992 Firebird manual shows the same arrow direction. There is a terminal access point where the arrow is pointing that is fed from the 10AMP Radio fuse that's above it.
Old Aug 15, 2019 | 10:01 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
So, that terminal only has power when the radio is is powered up? Or anytime the ignition is on?
Old Aug 15, 2019 | 10:13 PM
JT's Avatar
JT
The terminal, and other leg of the fuse, have power with key on as long as the fuse is good and in place.
Old Aug 15, 2019 | 10:24 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Ok, so the only reason it's called radio is that is the fuse that powers that terminal. Thanks for that.
Old Aug 16, 2019 | 07:35 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Well, that is why i specified accessory. There is a key position that is accessory only, if you turn the key back toward you instead of forward. Acc-->Off-->Run-->Start So that terminal and fuse works in Run and Accessory positions. There is also a terminal on the back of the fuse block if you need another one
Old Aug 16, 2019 | 09:48 AM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Ah, thanks for the clarification. 👍🏻
bbsr72
Apr 15, 2011 09:21 PM
csimpson1
Oct 6, 2009 01:34 PM
kretos
Oct 3, 2004 06:56 PM
mory
Aug 30, 2004 04:29 PM
white91formula
Sep 14, 2003 08:10 PM
