Help with wire
Old Aug 28, 2019 | 06:49 PM
moshyjoshy's Avatar
Car: 89 I-Roc Z
Engine: 305 5.0L
Help with wire
Can someone tell me what this is to? Also what is the black (melted) piece called so I can buy a new one? This is a 1985 305 TPI.
Old Aug 29, 2019 | 03:48 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Help with wire
Looks like the Oil Pressure and (possibly?) the AC signal wires,... IIRC there was a 2-wire connector from the ECM harness to the ENGINE harness on the from 85-87 TPI cars and this looks like that connection.
Old Aug 29, 2019 | 07:09 PM
moshyjoshy's Avatar
Car: 89 I-Roc Z
Engine: 305 5.0L
Re: Help with wire
What is the black piece called? I would like to fix it 😁
Old Aug 30, 2019 | 11:06 AM
Re: Help with wire
Connector
Go to the junkyard, take whatever thing that one is supposed to plug into with you, find one in a junk car that plugs into it, cut it off, take it home and splice it onto your car's wires with solder and heat shrink tubing. (NOT crimp splices, NOT electrical tape, etc.)
87BlazinIroc
May 26, 2021 09:11 AM
IROC-BOB86
Mar 2, 2015 07:20 PM
corvettespeed24
Aug 15, 2011 12:21 AM
IROCZ28dan
May 16, 2005 03:33 PM
POS350Z
Dec 4, 2004 12:21 PM
