Can’t find burnt wire.
Old Sep 3, 2019 | 12:56 AM
tbeyer's Avatar
I installed an active subwoofer on my 86 Iroc. I hooked the positive wire for the sub into the fuse box where it says “ign”. One day I was driving and something went pop. Now those “ign” ports on the fuse box seem inactive and my gauges don’t work, except for the speedometer which is mechanical. The gauge lights come on but no gauges. Also the ding sound for if you leave the keys in or leave lights on is sounding constantly when I turn on the headlights. It makes driving at night annoying. I thought maybe the fusible links blew but there’s no evidence of them looking burnt. Could they possibly be burnt on the inside? Am I looking at the right thing? What exactly should I be looking for?
Old Sep 3, 2019 | 07:00 AM
Re: Can’t find burnt wire.
Check your Gauges fuse.
That's not a particularly high-power source. Might want to either find something else to hook to, or use a relay with the coil fed off of that and the contacts fed straight from the batt.
Old Sep 3, 2019 | 12:45 PM
tbeyer's Avatar
No fuses are blown. That leads me to believe it’s the wire that powers the fuse box from the ign switch. Any idea what that looks like.
Old Sep 3, 2019 | 01:03 PM
It's pink.
Problem is probably not the wire. Probably the Gauges fuse. Just replace it.
Old Sep 3, 2019 | 10:54 PM
tbeyer's Avatar
The problem is that there are 7 pink wires coming into the fuse box. It can’t be the gauge fuse alone because all the fuse ports around it are also inactive.
The side effects of whatever happened are that the guages dont work and the warning ding is on whenever I turn on the headlights.
Old Sep 4, 2019 | 08:53 AM
GeneralDisorder's Avatar
You need a service manual with proper diagrams. Ebay has a lot of them cheap. Anytime I get a year or model I don't have a manual for I immediately buy all the FSM's for the car so when things like this come up I can pull a diagram for it.
GD
Old Sep 5, 2019 | 07:07 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fuse Ruse
You can list the ports that have no power.
IF the Gages fuse is good (
verify it with a meter, not just visually) you might have a broken pink circuit.
You will have to trace it to the point where you find power.
That’s where the break is.
The circuit eventually makes it’s way to the ignition switch.
Happy Racing !
If We Don’t Get Cawt We Ain’t Cheatin’
84 z28
Apr 20, 2007 02:30 PM
92camaroz28ss
Mar 30, 2007 12:37 PM
Bad-Newz
Jan 14, 2007 01:35 AM
Wootah
Jun 3, 2003 08:47 AM
larryddodd
Mar 12, 2002 06:53 PM
