Right power door lock not working
Old Sep 19, 2019 | 02:11 AM
Firebird2011's Avatar
Car: Pontiac Firebird Formula
Engine: 3.1 LH0
Axle/Gears: Automatic
As i mentioned in the title, I have this issue with the right power door lock, it doesn' t work at all. If I press the switches nothing happens and if I lock or unlock the doors with the left switch, the right one doesn' t work. I can open and close it just manually.
Any suggestion to fix it?
Thanks!
Old Sep 21, 2019 | 10:17 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Right power door lock not working
Did you remove the door panel and check the solenoid/wiring/linkage? I would start there, try moving the solenoid/linkage to see if it moves freely, spraying lube on the solenoid if its sticking.Check for corrosion on the connector, check wiring for cuts.Probably more, but thats all i can think of right now.
Old Sep 23, 2019 | 12:42 AM
Engine: 3.1 LH0
I still didn’t, I’m going to get into it this week and check the things you suggested. This car was a Knight Rider replica, and I remember when I was pulling off some wires from the lock switch something sparked around it. Maybe the switch is gone?
Old Sep 23, 2019 | 07:16 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Maybe checked for blown fuse/s if you caused a spark.
bigmacnz
Feb 9, 2011 12:04 PM
camarosource
May 22, 2004 09:44 PM
AstroturfHead
Mar 16, 2003 06:55 AM
TBI89Formula
Apr 7, 2002 09:08 PM
89FirebirdUK
Oct 31, 2000 07:52 PM
