1989 rs305 no power to fuel pump
Old Sep 22, 2019 | 03:24 PM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
I have searched this forum and I know there is many of these post on here.I have read and reread them and still cant pinpoint this problem.Car will start with starting fluid,but fuel pump will not come on. I unplugged it from the rear harness and it does work.I have power to relay and to fuse and to oil switch but its not getting back to fuel pump.Replaced relay,cause its cheap and I hear it click,but still no fuel pump
I believe its the tan and white wire through the harness on drivers side,put 12 volts to that wire and still nothing.Maybe as simple as a ground,but I need a schematic on the wiring,,any thoughts Thanks
Old Sep 23, 2019 | 12:10 PM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Re: 1989 rs305 no power to fuel pump
Gee thanks everyone...it was a bad ground
Old Sep 27, 2019 | 07:07 AM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
Lugnut where did you find the bad ground at? I am having the exact same problem.
Old Oct 15, 2019 | 12:32 PM
Godfearn's Avatar
I am curious on this one too. I just picked up a car, and the previous owner bypassed the oil switch altogether and ran direct power to the fuel pump from a toggle switch on the dash....
s10sbc350
Jul 27, 2022 05:47 AM
mikiman
Dec 1, 2018 11:49 AM
leezickmund
Carburetors
May 9, 2013 08:11 AM
Wagoneerlover
Dec 29, 2007 02:31 AM
89irocTPI
May 21, 2007 09:11 AM
