Instrument Cluster Lighting
Old Sep 30, 2019 | 08:03 AM
ZackZ420's Avatar
Car: 1991 CamaroZ28
Axle/Gears: Stock
Hey third geners. First off want to thank all the people who helped me on my Tach problem. So I figured if I am taking cluster out, some of the lights are dim in cluster so i am going to change. Wondering if they are different size bulbs in back of it. Want to go LED but maintain the stock color. Saw some on Ebay but am wondering what you guys think. Thanks
Old Sep 30, 2019 | 06:46 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Instrument Cluster Lighting
If you use the search feature in this (Electronics) and possibly the interior section as well for cluster or instrument lighting options you will discover a huge amount of threads with info covering your questions
( Far right end of the top blue bar where it says search this Forum) very useful tool...
Old Oct 1, 2019 | 08:13 AM
Firebat's Avatar
I wouldn't trust LED's from ebay. Go to superbrightleds.com, I have used them for years. 194 is probably the bulb size you want and they have them in many colors. Remove cluster first to verify and verify how many you need. It's not necessary to replace the blinker and brights indicators because they are usually bright enough.
Old Oct 1, 2019 | 01:41 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Sylvania has some nice 194 size LED in yellow(also white,red and blue) single chip with a diffuser cap,they fit same space as a 194.You probably will need to get some bulb sockets as GM was using one piece bulb/sockets in the early 1990s
Catman73
Jan 18, 2015 11:17 PM
DeathMetalTony
Oct 10, 2009 08:10 AM
JamesC
Apr 18, 2005 11:35 AM
