No headlights
No headlights
1992 RS no headlights, parking turn, tail, backup all work as well as flashers. I replaced headlight switch same problem. Is there a headlight relay on these cars i cannot find it. I checked all fuses, fusbile links nothing. Car starts and runs fine. I do have power to headlight with i did validate that with volt./ohm meter. Any help greatly appreciated
Car: 88GTA
Engine: 5.7TPI
Car: check
Engine: check
Transmission: check
Re: No headlights
No head light relay. If none of the head lights work, are they all burned out? The power for the headlights originates at the starter via a fusible link and is feed through the C100 bulkhead connector.
Then on to the head light switch.
Then on the high/low switch. Then out the C100 connector to the engine harness and on to the head lights.
Grounds for the head lights are picked up under the hood on the engine side of the radiator support,
RBob.
RBob.
