rear turn signal not working
Sorry for the repeat not sure if post worked first time. No power to yellow wire on left rear turn signal bulb but front signals working. No power from the switch on column for the yellow but tthe green right rear wire blinks with the right turn signal switch on.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Turn Style
The most likely cause is a bad turn signal switch.
However make sure it isn't the connector by using a voltmeter.
HappyRacing!
Headlight Goofs By Designers #15; TOO HIGH: Pickup truck headlights are mounted too high therefore they are not aimed onto the road, they are aimed into your eyes.
HappyRacing!
