Red Wire - Blower Relay??
Old Jan 5, 2020 | 02:18 PM
Dholland17's Avatar
Car: 1983 Z28 T-tops
Engine: 350 GM Crate
Hi all,
Is this the blower relay? Where does this red wire(circled) connect to for power? Mine is not tied into anything currently, just loose.
thanks
Old Jan 5, 2020 | 02:45 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Red Wire - Blower Relay??
Yes , it is the blower relay (for high speed only) and the red wire connects to one of the car's fusible links .
Old Jan 5, 2020 | 04:02 PM
Yes that is the blower high-speed relay.
The red wire gets/got its power from somewhere over near the main bulkhead connector, below the master cyl. On Orange's diagram, it's near the top at the far right, labelled "Fuse Link Red". It has/had its own fusible link. You can hook it to anywhere that has very high-power 12V available to it at all times; you could pick it up at the big stud on the alt for example (which is probably the best place really, since that point has the highest voltage available anywhere in the car), or the stud on the starter where the batt cable goes. I'd recommend using #10 or 5.0mm wire, with a "rust" colored fusible link at the end closest to the batt. Solder the new wire to what's left of the original red wire where it's been cut; NOT just crimp it, and above all, NOT a wire nut; and run it NEATLY inside one of the factory harnesses to wherever you decide to hook it to.
Interesting how whoever had their peterpullers in there, left all the AC connectors piled in that one area.
There should be a license required to buy a pair of dykes, and anybody caught with a pair without a license should be sentenced to hard time.
— can't remember who said that
Old Jan 5, 2020 | 06:53 PM
Dholland17's Avatar
Fantastic! Love this forum, thanks guys. Why does a blower need so much power? Isn't just powering the fan in the blower assembly?
Old Jan 5, 2020 | 10:01 PM
It's the power for the blower high speed. Draws around 30 - 40 amps. "Just" the blower motor. VERY high power. One of the most power-demanding things in the whole car.
Don't ask why; it just IS. Provide it what it wants, that ye may be cool.
reefland
Feb 7, 2023 11:28 AM
havacamaro
Mar 16, 2016 08:19 AM
hitman0187
Oct 14, 2012 03:17 PM
hitman0187
Oct 11, 2012 03:32 PM
MasterEvilAce
Dec 15, 2002 02:27 AM
