Old ecm wiring
Old Jan 26, 2020 | 04:35 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Old ecm wiring
Removed old stock ecm and installed holley efi. Can these harnesses be just left as is or can they be used for anything?
Old Jan 30, 2020 | 05:10 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Old ecm wiring
Some of the PINK/BLACK wires might still be "hot" when the key is turned, Any ORANGE wire might carry full time voltage, and any BLACK or BLACK/WHITE might be a usable ground.
You might be able to use any of the remaining wiring depending on what you plan to use it for. Those plugs are called C207 and C221; Here is a list I made showing what each circuit is for in your 86.
1986 & 1987 C207 ( TPI )
PIN--Color--From / To--(Notes)
A Brn ALDL / ECM (AIR control)
B Red ALDL / Fuel Relay ( TPI )
C Brn/Wht ECM / CE Light ( TPI )
D Tan/Wht Fuel Relay / Fuel Pump ( TPI )
E Wht/Blk ALDL / ECM (test)
F Pnk/Blk IGN fuse / EGR-ECM
G Pnk/Blk Gage Fuse / Burn Off Relay ( TPI )
H Tan/Blk ALDL / TCC-ECM
J Org ALDL / ECM ( TPI )
K Brn ECM / Speed Buffer
L Tan/Wht Fuel Relay / Fuel Pump ( L69 )
M Blk/Wht VSS,P/N switch / Grd
N Org/Blk ECM / P/N switch
P Ppl Brake / TCC
R Ppl/Wht Crank Fuse / Cold Start-ECM ( V6 )
Plug C221
A Pnk/Blk Inj2 Fuse / Even Fuel Injectors
B Lt Green Back Up Switch / BU Lights ( V6-T5 )
C Brn Fuel Pump-Fan Fuse / Fan Relay ( V6 - TPI )
D Pnk/Blk Inj1 Fuse / Odd Fuel Injectors
E
F Dk Blue Back Up Fuse / Back Up Switch ( V6-T5 )
Hope that helps !
Old Jan 30, 2020 | 05:28 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: Old ecm wiring
Awesome thanks for the info.
Old Feb 3, 2020 | 09:32 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: Old ecm wiring
how did you make out with your wiring? did everythign work out?
I am a week away from installing a new engine with a holley sniper on it. I eliminated all oem ecm wires, and kept the c207 wires inside the cabin, but eliminated them going into the engine bay. from looking at this layout of the wires, I see that I might need to run a ground at the black/white wire on the c207 (pin M) and possibly possibly the purple (pin P) wire if I want to retain my on/off toggle switch for my current TCC lockup setup.. Looks like all other wires at the C207 wont be needed? am i overlookign anything?
i was talking to scooter, and he suggested using one of the injector wires (pin A or D) on the C221 connector to trigger the sniper unit since it is hot in crank and hot in run. I think that is what we discussed.
everythign else on the C207 and C221 can be left unconnected and unused? or did you find anything else that needed tobe wired ?
Old Feb 4, 2020 | 07:04 AM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: Old ecm wiring
My car is all wired up. Had a buddy help me out with the wiring. Wiring is not really my thing. I didnt have to use any of the wires from the old ecm plug. I was looking to use some of the power wires to run some interior accessories .I also used a toggle switch to control tcc. I didnt end up using the holley input output harness to control tcc. Some of the guys were having a hard time setting that up to work properly on the 700r4.
Old Feb 4, 2020 | 10:25 AM
IROCZman15's Avatar
Car: 1987 IROC-Z
Re: Old ecm wiring
WOAH, I didnt know the sniper could control TCC! yea, I didn't know that was an option, I will have to look into it, that might be a better way for me to control TCC instead of a trans kit, or reworking my current toggle switch for TCC control. cool
Old Feb 4, 2020 | 11:19 AM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: Old ecm wiring
Not sure if the sniper has that option. I have the holley hp
Old Feb 4, 2020 | 11:21 AM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: Old ecm wiring
Just looked it up, input/output harness is for hp and dominator only
Old Feb 4, 2020 | 05:13 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Re: Old ecm wiring
Ah!, bummer. oh well, I know I can figure something out. I don't mind not having lockup for a little bit while I get all the other bugs sorted out with the new 406 engine install. I can always keep using my toggle switch setup, or go with one of the professional kits for TCC control. thanks for checking for me.
loquito
Jun 9, 2009 09:18 PM
87tpi7749
Oct 25, 2006 06:38 PM
fire1976
Jun 30, 2004 10:12 PM
craiger
Feb 27, 2002 12:59 PM
tpic1500
Jan 5, 2001 12:05 PM
