Fuel Pump Harness Connector to Bulkhead
Old Jan 30, 2020 | 11:00 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Does anyone know what size the 3-pin type connector is that goes into the bulkhead fitting for the fuel pump and level gauge? Or does anyone have a good one off a old harness. Want to use the OEM bulkhead connector for my build.
Old Jan 30, 2020 | 11:03 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel Pump Harness Connector to Bulkhead
You might try this one
https://www.corsa-technic.com/item.p...category_id=83
take a close look at the slots on the connector to make sure they will line up.
or are you Looking for the female side ?
Old Jan 30, 2020 | 11:08 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
I bought one just like that and does not work. I need one with female pins in it to fit I believe.
Old Jan 30, 2020 | 11:20 AM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
The OEM bulkhead has a groove guide on the center top and the lower left for the connector slots. The one I bought had two top grooves on the first and third pin opening. So it seems the one I need is special.
Old Jan 30, 2020 | 04:27 PM
Drew's Avatar
It's not a typical Weatherpack connector, you need one with the provision for the extra lock.
Try Delphi / Aptiv 12020829
https://www.mouser.com/ProductDetail...yku%2FVp55o%3D
Use the datasheet to find the matching terminals.
Old Jan 30, 2020 | 05:05 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Thanks.
Old Jan 30, 2020 | 07:21 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
You talking about the connector behind the rear seat? It's in my build thread.
bphage
Aug 24, 2019 03:55 PM
Mg73Mx99
Mar 18, 2017 09:41 AM
Maverick H1L
Mar 29, 2010 07:54 AM
