2 wire fog light switch 85 iroc tan wire
Old Feb 4, 2020 | 07:38 PM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
Axle/Gears: ls1 rear with 3.23
im trying to re wire my fog lights. looking for some clarification. I tried lookin at diagrams but only ones I find are from later years, 86-87 with a fog light relay. 85s had no relay. the diagrams from 85 have no fog lights in them.
I have two wires coming from the fog lights, black, and purple.
I have two wires coming from fog light switch, purple, and tan.
purple to purple
black to ground
tan to ???
Old Feb 5, 2020 | 11:05 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 2 wire fog light switch 85 iroc tan wire
TAN ( BROWN ) wire is the power wire to the switch.....
This should help, It's from an 87 Camaro. While it shows a relay,... the relay can be omitted for a direct connection to full time power. Keep in mind the Fog lights will turn on with no headlights, with headlights, AND with High Beams if you don't use a relay.
https://www.thirdgen.org/forums/elec...og-lights.html
** IIRC the 85 (only) had a Tan (or BROWN?) wire leading from the dash harness as a power source for the fog Lights. This is a pic of an 85 dash harness and I *THINK* the wire/plug marked with an "X" is the Fog Light connector.
Old Feb 6, 2020 | 10:51 AM
kevwalt22's Avatar
Car: 85 IROC
Engine: ls1
Transmission: t56
awesome thanks! this is exactly what I needed. now I just have to locate that brown wire.
Solders18
Jun 11, 2013 08:49 AM
N20WS6
May 12, 2013 08:57 PM
BluFBdy
Feb 27, 2008 06:45 PM
Codename 47
Aug 8, 2004 04:04 PM
BigH
Dec 8, 2000 09:37 AM
