86 chevy Camaro ac clutch cycling switch
Re: 86 chevy Camaro ac clutch cycling switch
Right: power in that version comes from the control head via the green wire to the low-pressure switch, then to the power steering cutoff switch via the blue wire, then to the control module & compressor relay.
I'd suggest getting another one of that connector at the junkyard, rather than trying to splice to wires that short. The same connector is on MILLIONS of vehicles from that era.
no junk yard has this vehicle in there
blue goes to the compressor its self then?
