tachometer messing up.
Old Apr 14, 2020 | 08:40 PM
GreenieG's Avatar
Car: 1985 IROC-Z
Transmission: T5 manual
my stock tachometer used to work just fine, now when i start my car the needle will wiggle a little for a second but then will not read the RPMs. I dont know if its related but my oil gauge now just zooms up to the max reading on the gauge as well. any insight is appreciated!
Old Apr 15, 2020 | 11:58 AM
885speed's Avatar
Car: 1988 Camaro
Engine: LR4
Axle/Gears: 3.23posi/disc
Re: tachometer messing up.
Hmm.. That's not the normal mode of failure for the tachs on these cars.. First thing I'd do is take the cluster out and inspect/clean the connections as well as inspect the printed circuit board on the back for any issues.
If your tach circuit board ends up being bad, I would highly recommend visiting https://www.cajuntachshop.com/ and picking up one of their tach circuit boards.
I did for my car, and it was worth every penny IMO.
EDIT: By "not read the RPM's" do you mean it just pegs to the max? If so the Cajun tach board will fix it.
Also, don't bother trying to get a used tach on ebay. Your chances of getting a good one on there that will last is basically zero.
Old Apr 15, 2020 | 01:18 PM
GreenieG's Avatar
Car: 1985 IROC-Z
the needle stays at zero. when turn the key to the start position the needle will briefly wiggle but will not do anything else from there. i never had any problems before with it. i checkd the wire coming from the distributor and all seems well on that end as far as i can tell so idk.
Austin Jochum
Mar 17, 2020 01:47 PM
valleyguy
Nov 22, 2007 06:59 AM
craparo
Apr 28, 2007 09:43 PM
Zutron
Apr 24, 2002 01:13 AM
