19992 RS Camaro No Headlights
Old Apr 24, 2020 | 11:22 AM
Bob Thomasson's Avatar
I have checked all fuses all are good, replaced headlight switch. First question is there a headlight relay if so where is it? All other lights work fine parking, turn, backup, and brake. I am thinking the dimmer switch located on top of steering column that has the rod running down to it, any ideas? Thanks in advance for any help
Old Apr 24, 2020 | 12:19 PM
Re: 19992 RS Camaro No Headlights
Yes that's the dimmer switch.
Easy enough to check for 12V coming into it and leaving it... yellow is 12V coming to it from the HL sw, tan is 12V coming out to the low beams, light green is 12V to the brights. Start at yellow; if there's no 12V there when you pull the ****, work back toward the HL sw, and if there is, work forward toward the bulbs.
Anything else not working at the same time? Parking lights, dash lights, etc. work?
rbrackett
Aug 26, 2017 10:38 AM
fenderman93
Apr 26, 2017 09:44 AM
Njcamaro27
Feb 3, 2010 04:32 PM
PaladinMachina
Sep 20, 2007 06:47 PM
vampiroc
Oct 21, 2004 04:32 PM
