headlight problem
Old Oct 20, 2004 | 12:35 AM
vampiroc's Avatar
Car: Z28
headlight problem
This just happened recently, not sure what the cause is. all four of my headlights do not work. they don't come on, don't even get power. The bulbs are all good and the low beams are H4s, but this isn't the problem, I've run H4s for over 2 years now with this car. The foglights, and turn signal lamps (side and front) come on however as do the gauges, tail lamps, and the interior lights when I turn the **** to override, which is the big mystery. Anyone have a clue as to what the problem might be? I thought there might've been a relay or fuse that went bad, but there are no relays or fuses for the headlights alone that I have encountered. Car is an '89 camaro.
Old Oct 20, 2004 | 09:43 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Check your dimmer switch which is mounted at the base of the steering column. This is the switch that turns the high beams on and off.
Old Oct 20, 2004 | 09:48 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sorry, forgot to include this.
Old Oct 21, 2004 | 11:12 AM
vampiroc's Avatar
Car: Z28
I assume the dimmer switch is inside in the car near the firewall and not outside? do you have a picture of it. there is a rats nest of wiring and nothing seems to stand out at all.
Old Oct 21, 2004 | 11:23 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
That is because it is on the top side of the steering column and to get a good look at it you will need to lower the steering column. Here are a couple of pictures for you.
Old Oct 21, 2004 | 11:24 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
page 2
Old Oct 21, 2004 | 11:57 AM
vampiroc's Avatar
Car: Z28
thanks trickster. Would it be more common that something came loose or that the switch is broken and needs to be replace in your opinion?
Old Oct 21, 2004 | 12:20 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I would check the wires at the switch first and then replace the switch if the wires appear to be okay.
Old Oct 21, 2004 | 04:32 PM
vampiroc's Avatar
Car: Z28
I'm pretty sure I've found it. its a whitish looking thing on the steering column with a single plug going into it. about 3 inches away from it are the brake light actuators.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
