dakota digital buzzer
Old Jun 11, 2020 | 08:59 AM
kawaslut's Avatar
I am looking for some direction. I purchased the Dakota digital gauges and after the install the interior car buzzer will not shut off after the car is started and doors closed. Could some one lead me in the right direction?
When I open the door the floor lights come on, put the key in the ignition (the buzzer starts buzzing) start the car, shut the door (floor light goes off) and the buzzer never turns off.
Old Jun 12, 2020 | 06:41 AM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
Re: dakota digital buzzer
Where is the source of your IGN power to the DD module coming from? You have tied into the warning buzzer circuit somewhere, and the IGN feed would be the most likely source. There should be a key on power source at the fuse block that you can use that will not be tied into warning circuit.
SparksAj
Mar 27, 2014 07:02 AM
Firechicken86
Dec 18, 2013 11:31 AM
wrsjr
Feb 10, 2012 08:18 AM
rondubbs
Sep 3, 2002 09:59 PM
