Connector Diagrams
Old Jun 14, 2020 | 07:39 AM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
Connector Diagrams
Is there a resource or anything where I can find info on what each connector is and what circuits are in them. I have the service manual which has a nice mechanization foldout and lists circuit numbers and wire color/gauge but no circuit description. The electrical supplemental book has connector faces and cavities with vpps but no names. Most of the stuff I can figure out based on where it is and thankfully the C100 is well documented, but its the random inline connectors that are the issue. What I'm mainly after is a full pinout and description of the two IP inlines that supplement the ECM on the right H-Pillar passthrough of the engine harness. One is a clear 15w and the other is a Grey 6w. I believe the clear one is called C228 idk about the grey one. It kinda looks like they are for the relays and stuff but I want to make sure. My goal is to totally eliminate that whole mess and block off the passthrough. I can move one or two circuits to the C100 but if its more than that or some big gauge (2.0+) then ill have to run them out that way somehow. The car is/was a dead base 1987 v6 (LB8), Auto Trans.
Old Jun 14, 2020 | 10:08 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Connector Diagrams
This might help:
1986 & 1987 C207 ( TPI )
PIN Color From / To (Notes)
A Brn ALDL / ECM (AIR control)
B Red ALDL / Fuel Relay ( TPI )
C Brn/Wht ECM / CE Light ( TPI )
D Tan/Wht Fuel Relay / Fuel Pump ( TPI )
E Wht/Blk ALDL / ECM (test)
F Pnk/Blk IGN fuse / EGR-ECM
G Pnk/Blk Gage Fuse / Burn Off Relay ( TPI )
H Tan/Blk ALDL / TCC-ECM
J Org ALDL / ECM ( TPI )
K Brn ECM / Speed Buffer
L Tan/Wht Fuel Relay / Fuel Pump ( L69 )
M Blk/Wht VSS,P/N switch / Grd
N Org/Blk ECM / P/N switch
P Ppl Brake / TCC
R Ppl/Wht Crank Fuse / Cold Start-ECM ( V6 )
Plug C221
A Pnk/Blk Inj2 Fuse / Even Fuel Injectors
B Lt Green Back Up Switch / BU Lights ( V6-T5 )
C Brn Fuel Pump-Fan Fuse / Fan Relay ( V6 - TPI )
D Pnk/Blk Inj1 Fuse / Odd Fuel Injectors
E
F Dk Blue Back Up Fuse / Back Up Switch ( V6-T5 )
Good Luck !
Old Jun 14, 2020 | 10:22 AM
exiled350's Avatar
Thanks! That makes it a whole hell of a lot easier. Beats trying to trace a line over four pages lol. Even better it looks like I can scam the brake/tcc circuit from C207 and run it out the C100 for my 700R4 instead of trying to splice into the brake switch.
Old Jun 14, 2020 | 03:27 PM
John in RI's Avatar
Glad to help !
Funny thing; I made the list (a long time ago) by searching thru the 86 & 87 Electrical "supplemental"; about 140-150 pages ! While those manuals are color coded and easy to read,.... those years don't have a section covering the C207 specifically like later shop manuals. To get the info I had to search each schematic looking for each and every individual circuit. ( ID'd the reverse light wires in the reverse light schematic..... ID'd the Speed Buffer wire from the Instrument cluster schematic, and so on. ) I think 88 was the first year the C207 connector was actually described in detail for the first time in the service manuals.
Weffy
Mar 17, 2010 03:28 PM
Tehsocks
Apr 29, 2009 08:34 PM
cabech984
Jun 13, 2007 10:37 PM
bluegoose
May 6, 2007 05:14 PM
Snuffit
Jul 8, 2005 02:25 PM
