Lights pop up
Old Jun 14, 2020 | 04:37 PM
Rick1616's Avatar
Lights pop up
Hello all I have a 91 T/A GTA as soon as I turn the key even before firing it up the lights pop up and stay up all the time, lights are always on, gauge lights included does this sound like a faulty switch or messed up wiring?
Old Jun 14, 2020 | 09:18 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Lights pop up
I would start with the switch, yes.
Old Jun 17, 2020 | 09:39 PM
Sqanch88's Avatar
Car: 1990 Pontiac Trans am GTA
Transmission: Automatic
Re: Lights pop up
Hey man check your dash pad by your passenger front speaker. If there is a little black plastic circle its a sensor called auto magic and if it senses low light it makes the headlights come on auto when you put the key into on position. So for example even in my garage it would come on unless I put a flash light on top of the sensor perhaps its dusty or needs to be cleaned.
Hope its the same issue i had bro! Good luck!
Old Jun 19, 2020 | 11:24 PM
Sqanch88's Avatar
Re: Lights pop up
let me know if my above answer solved it for you!
Old Jun 29, 2020 | 02:09 PM
Rick1616's Avatar
Re: Lights pop up
Yes! That's what it was, the previous owner had the dash off and that sensor was barried under the dash. Thanks that was so helpful. 2 days of messing around.
Old Jun 29, 2020 | 02:12 PM
Rick1616's Avatar
Re: Lights pop up
I have another ?. So my 91 GTA has the 305, 5 litre, when I replaced a push rod last week I noticed the set bolts are all screwed down tight does this mean I do not have to make any adjustments just tighten all the way down? I've read on hydraulic lifters they dont have to be adjusted is this true?
Old Jun 29, 2020 | 02:38 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Lights pop up
There is a proper way to set the lifters , , , and "the set bolts are screwed all the way down tight" most certainly AIN'T it !!!!!
PS , Having them tightened down like that is why your in there replacing pushrods in the first place ,
which would be the result of your valves trying to poke holes in the tops of your pistons .
Old Jun 29, 2020 | 02:51 PM
Rick1616's Avatar
Re: Lights pop up
Ya that's what I thought, this is how I bought the car probably why I got it so cheap there was a few things wrong with it that looked like attempted fixes. Thanks for the reply I'll make sure I set them properly.
Old Jun 29, 2020 | 04:53 PM
Rick1616's Avatar
Re: Lights pop up
So if I'm adjusting the valves with the engine running do I back the nut off till I hear the ticking then turn til no ticking and then is it a quarter or half turn after that? I cant turn the motor over from the drive pulley
Shadyredeyes
Feb 12, 2010 10:57 AM
PaveTim
Jan 9, 2004 06:27 PM
