T.L.
close
- Join DateSep 1999
- LocationColorado USA
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car'83 Firebird (T/A Clone)
- Engine350 with L-69 components
- Transmission700R-4, 2000 RPM stall converter
- Axle/Gears10-bolt/3.73 ..
- Liked:823 Times in 631 Posts
What is the pigtail for? The alternator output wire?...
What application is it on? Year, camaro, firebird, tbi or tpi. Pictures if you could. It possibly is a aftermarket battery cable
T.L.
close
- Join DateSep 1999
Where did the factory connect the alternator output wire to on a '83/'84 thirdgen? Was it connected directly to the Positive battery terminal? Was it connected to the pigtail wire on the Positive battery cable? Was it connected to the Positive terminal on the starter?
Someone here must know...
gt4373
close
- Join DateNov 2011
- LocationCT
- Car1984 Chevrolet Camaro Z28
- Engine5.0 Liter 4-BBL V8 High Output
- Transmission5-Speed Manual
- Axle/Gears3.73
- Liked:355 Times in 205 Posts
My 1984 Has Two Wires Going To The Pigtail On The Pos Cable,The Thicker Wire Goes To The Alternator The Other Feeds To A Main Harness.
T.L.
close
- Join DateSep 1999
Thank you, gt4373...
