ECM Wire removal
Old Sep 30, 2020 | 12:15 AM
Goattman's Avatar
Car: 1992 Camaro RS
Engine: 350 SBC
Axle/Gears: 3.42 10 Bolt
ECM Wire removal
I'm trying to remove specific wires from my ECM, I've singled out the wires that I can remove and I've removed them from the ECM terminal. However, in continuing I got to the part where all the wires are collected to go through the passenger fender and up into the engine bay. I don't know what this part is called, but I don't know how to remove wires from that piece, simply because all of the wires are encased in a resin/rubber-like material. Does anyone know the best way of getting the wires out of that piece?
Old Sep 30, 2020 | 06:59 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: ECM Wire removal
The only way is to cut them...
Old Sep 30, 2020 | 07:51 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The pass through connector needs to be taken apart and soaked in fuel to remove the glue.
there is a wire holder inside the connector that the wire clip into.
efi connector makes a new design for using with aftermarket harness. It’s not a cheap item.
Old Sep 30, 2020 | 07:54 AM
Engine: Lb9
Transmission: M20
https://www.eficonnection.com/home/p...ebird-bulkhead
Old Oct 28, 2020 | 03:32 AM
Goattman's Avatar
Car: 1992 Camaro RS
Engine: 350 SBC
For anyone who's going through the same thing as I was. To remove the wires from that resin/rubber-like material. Take a heat gun to the piece and it will start to melt off, similar to hot glue. Once it was melted enough, I was able to remove all the wires from it.
jbander
Jan 28, 2020 11:10 AM
Ryknow86
Dec 14, 2003 07:22 AM
SinthetikIroc
May 18, 2003 05:56 PM
