Removing old auto alarm system
Old Nov 16, 2020 | 10:30 PM
msammy93's Avatar
Car: 1988 Trans Am GTA
Engine: 383 TPI
Transmission: 700r4 3000 stall non-lockup
Axle/Gears: 12 Bolt Rear 3.73
So my gta has a UNGO TL-1450 auto alarm system. When unlocking my power door locks using the power lock button it sounds the siren for a brief second. I do not like this and want to remove it. Is there any special procedure for removing these old alarm system? Or can I just disconnect all the wiring going to it and wrap them up?
Old Nov 17, 2020 | 07:16 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Removing old auto alarm system
If you aren't experienced in car electrical system wiring, your best first step would be to try to obtain a copy of the installation instructions for that unit. Knowing what circuits were cut/modified will make restoring the wiring back to stock much easier.
One other thing; when you're ready to start splicing wiring back together, don't use Scotchlok connectors; solder the wires and cover the connections with heat-shrink tubing.
Old Nov 17, 2020 | 07:21 PM
msammy93's Avatar
Engine: 383 TPI
Thanks for the advice. It seems that the unit is so old that there is no available manuals online for it. This sucks lol
Old Nov 17, 2020 | 07:55 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I would get the factory service manual instead, that will be better for understanding what is in the car.
I would say most alarms are just some sort of starter interlock system with other features, like lights activation and maybe the horn. Have you started looking at the alarm system? Mine has wire descriptions so you can know what it is connected to, you might get lucky there
If you have to splice wires, use non insulated butt connectors with adhesive lined heat shrink, faster/easier/better than soldering
soul.justice
Mar 18, 2013 03:20 PM
88 TA GTA
May 12, 2011 08:53 PM
LTL_DMON
Sep 21, 2009 10:48 AM
MechCD
Jun 29, 2003 01:09 PM
Keith5
Aftermarket Product Review
Mar 12, 2002 10:36 AM
