Door jamb switches won’t go in
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
I know this is a stupid question, but how do you get these little boogers to screw in? I can’t get either of them to catch the threads.
I’ve got the right part numbers, etc.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Pin Not In
Sounds like the threads in the car are damaged or the jamb switches' threads are bad.
You can try re-tapping the car or re-dieing switches.
Happy Racing!
Help Combat Global Cooling - Accelerate As Fast As Possible
Happy Racing!
Car: '88 GTA
Re: Door jamb switches won’t go in
That’s what I was thinking. I have a tapping kit, but it’s metric. I ordered a standard set, should be here tomorrow. At least I’ll be able to die the switches and see what thread they are.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
I always thought there was a nut behind the door jamb and the switch just passes thru.
