Maf sensor relay
Old Feb 17, 2021 | 05:53 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Maf sensor relay
I picked up a 85 Camaro for my daughter. Has been hacked up. First. Where is the maf sensor relay supposed to be located? Also AutoZone said they couldn't get it. Motor parts and bearings gave me one has all 5 pins like fuel pump relay. the jacket or blade near front buy the battery cut up bad
Old Feb 18, 2021 | 12:17 PM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
Re: Maf sensor relay
The "relay" is actually in a module piggy-backed to the ECM, if it hasn't been converted to a '86-'89 computer.
The module is ridiculously expensive. They can be found used.
Old Feb 18, 2021 | 12:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The burn off module is like stated attached to a bracket on the ecm.
power relay next to the brake booster.
Old Feb 18, 2021 | 01:21 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
I got a 85 Camaro shop manual and it shows the relay passenger side front. Doesn't show a burn off like the 305tpi have. Will a fuel pump relay work? I have a 5 pin relay like the fuel pump type. The Po cut wires and looks like they bypassed the relay
Old Feb 18, 2021 | 01:35 PM
Engine: Lb9
Transmission: M20
Maybe mistaken on power relay but pump relay should be by the booster
only relay by the radiator should be electric fan.
Old Feb 18, 2021 | 06:04 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
85 TPI MAF burn-off relay is as Brian described; 'piggy-back on the ECM. Here is the 85 TPI schematic:
Here is a link that shows what it looks like:
http://airflowmeter.name/1985-camaro...5-tpi-z28.html
My guess is that you're looking at the V6 MAF diagrams........
Old Feb 18, 2021 | 06:42 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
I have a 2.8 v 6
Old Feb 18, 2021 | 07:01 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
My question is, can a fuel pump relay be used in place of the maf relay
Old Feb 18, 2021 | 08:44 PM
John in RI's Avatar
Compare the PN's and see if they are the same. If they are not the same PN,... I would GUESS no.
Old Feb 18, 2021 | 09:09 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
The diagram shows them looking the same. But the maf relay has one pin empty on the connector
Old Feb 18, 2021 | 09:30 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
I've noticed that the radiator fan relay is pinned the same as the maf relay. Even though the diagram shows the fuel pump relay and the maf relay with the same picture emblem thing. See the fan relay on the far left is 5 blade with only 4 being used. Same 4 as the maf relay.
Old Feb 18, 2021 | 09:33 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
So I would guess I need a fan relay and trace the wires to get it back factory
Old Feb 19, 2021 | 12:27 AM
John in RI's Avatar
Looks like the MAF relay has should have 5 pins,.. but only 4 are used. Since the car will run without an AC relay and it will not run without the fuel pump relay,.... I'd try swapping the AC relay and see if the car runs OK and what-ever problem your having clears-up. Plenty of time to buy another AC relay ( or the exact MAF relay depending on PN ) before the summer gets here.
Old Feb 19, 2021 | 07:36 AM
Bobby Suth's Avatar
Axle/Gears: 273?277
Yes. 5 is what the parts store said it called for in the computer. I got it and will try it. Only cost 12.00
patgta
Aug 4, 2024 08:15 PM
myzticc66
Oct 30, 2018 02:29 PM
#32pontiac
Aug 11, 2014 03:53 PM
johnny89345
Apr 14, 2009 11:02 PM
del91_305
Feb 21, 2007 09:38 AM
