how to convert my mast antenna to power antenna
Old Mar 10, 2021 | 08:06 AM
2Formula's's Avatar
Like to convert my 90 bird from mast antenna to power antenna. I have the correct antenna for the conversion. The wiring is correct. But I do not have an existing relay in the dash. Also, how do I wire to the radio from the relay?
Any help would be appreciated.
Old Mar 22, 2021 | 05:08 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Re: how to convert my mast antenna to power antenna
You need the wiring diagram for the setup for starters. Also google this and I am sure you will find videos and write ups on this.
Old Mar 22, 2021 | 08:18 PM
2Formula's's Avatar
you think that either one of your suggestions didn't already occur to me already?
Old Mar 22, 2021 | 11:37 PM
Denn11's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 305
Axle/Gears: 9 Bolt 3.45
Got this diagram off the forums a while back. I did a search for it. Much appreciation to the person who posted it.
Disclaimer: It is for a third gen, and may or may not exactly match your particular configuration. Use as a guide only and at your own risk. Good luck.
OP, you are off to a wonderful start on these forums. Smart *** replies are always appreciated (by the way, that is sarcasm)
Old Mar 23, 2021 | 01:55 AM
Engine: 5.7
Axle/Gears: Stock
Well good grief you are welcome...sorry I wasted my time. Smarta** indeed.
Old Mar 23, 2021 | 03:44 AM
2Formula's's Avatar
Thanks. That's out of the service manual. I actually have two cars a 90 and a 91. The 91 has a power antenna. I compared both even bought the relay. I'm good from the antenna to the relay but the relay to the radio will require cutting and splicing and soldering at both ends. I don't think it's worth it. O I paid a lot of money for a reconditioned ux1 radio and I don't want to mess things up. There isn't much wire to work with back there so I think I will just live with the mast antenna and keep the new power antenna as a spare. I got it real cheap. Thanks for your time.
formula00ra
Car Audio
Mar 21, 2021 06:57 AM
1988350bia
Sep 12, 2009 02:08 PM
80schild
Car Audio
Aug 27, 2008 06:17 AM
PAformula
Mar 22, 2007 06:53 PM
nagga
Dec 30, 2001 11:19 AM
