How to convert from mast antenna to power antenna
Car: 1990 & 1991 Firebird Formula 350's
Engine: 350 ci
Transmission: T 5 & 700r4
Axle/Gears: 3:23 & 3:27
Like to convert my 90 bird from mast antenna to power antenna. I have the correct antenna for the conversion. The wiring is correct. But I do not have an existing relay in the dash. Also, how do I wire to the radio from the relay?
Any help would be appreciated.
Re: How to convert from mast antenna to power antenna
I'm thinking of doing he same swap on my 85 Trans Am. What is the "right" antenna that you purchased? I used a Dorman replacement on my 78 Corvette that has held up well over the years. Was thinking of using the same for this swap.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Post #2 here. Pic of said antenna at the bottom.
https://www.thirdgen.org/forums/elec...na-wiring.html
