Hatch motor works but starts smoking
Old Mar 21, 2021 | 02:11 AM
187RS's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: T5 5 speed
Axle/Gears: N/a
1989 camaro rs 5.0 tbi 5 speed
when I bought the car a rat or something chewed through the wires that connect to the hatch , right near the driver rear of the trunk.
connected Wires to the best of my knowledge and replaced the broken guides and the pull down motor. When I shut the hatch it closes , when I release the hatch it makes a loud thunk sound like it was way too tight. Leaving the hatch open the motor begins to get hot. Is there a limit switch ? I’m assuming some wires are incorrect or faulty but because the hatch is working properly it seems to me there’s a limit switch that doesn’t know what to do. It closes (in my opinion) too tight as if it pulls down until it cannot pull any tighter, and when it opens its like it tried to keep working and smoking. Open to any criticism and what not I’ve read some wiring diagrams I’m not the best with them but do understand them. If someone could draw up a easier to read one or help me isolate my problem I’d be appreciative. Thank you
Old Mar 25, 2021 | 12:09 PM
187RS's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: N/a
Re: Hatch motor works but starts smoking
Anybody? Question being is there a limit switch ? Does anyone have a good wiring diagram or easy to follow one ? Need to know wires to relay and wires to motor please and thank you
Old Mar 25, 2021 | 12:41 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
try to adjust the motor position for depth of hatch when it closes. Adjust it loose (high) and see if that solves the release issue, then adjust for best operation and fit.
Old Mar 25, 2021 | 01:06 PM
187RS's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: N/a
so adjust the mounts or the motor itself? And when you say depth of hatch when it closes you mean the highest it will go and make contact?
Old Mar 25, 2021 | 01:21 PM
naf's Avatar
naf
I have an '87 and it looks like it may be different:
https://www.thirdgen.org/tech/hatchpulldown.pdf
Old Mar 25, 2021 | 01:22 PM
naf's Avatar
naf
wait
go through the link and there are instructions for the later hatch pull down units.
Old Mar 25, 2021 | 05:36 PM
187RS's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: N/a
wait
the motor and slides were broken along with wires were chewed , I fixed the wires to the best of my knowledge and I replaced the motor and slides. I had to sand down my slides to make the motor actually slide up and down but
I can try and pull it apart and do this but I’m not sure if any of it will fix my problem. The only thing I see is that if it “continues to run” it’s a problem with the gear nut. So I can remove it all and make it “8 revolutions” and see what happens. Thank you
Derek The Great
Sep 25, 2011 11:16 AM
novafirebirdguy
Aug 23, 2009 09:00 PM
iroc_steve
Feb 17, 2008 09:36 AM
Monster Zero
Sep 25, 2006 10:59 PM
88TRANS
Oct 30, 2002 07:18 AM
