Headlights won't go up
Car: 1988 Firebird Formula
Engine: 350 - 4BBL
1988 Firebird and the headlights won't go up. I read a lot of different threads trying to find the my 'specific' problem, but didn't see it. Though there are a LOT of threads. So here goes:
I replaced the bushings in both motors as the headlight buckets were free wheeling. Now both light buckets will go down - but not up. I can manually crank them up, but the lights on won't activate them up - they are silent. Lights off will pull them down.
Thanks for any help with this
Car: '89 Firebird
Engine: 7.0L
Re: Headlights won't go up
This might be helpful, Post #1277. But don't reply to that thread, keep the conversation here, please.
https://www.thirdgen.org/forums/ltx-...ml#post6307102
Car: 1984 T/A
Engine: LQ4
replace the headlight control module on the firewall. yours being an 88 can only be replaced with an 87-89 module. The 90-02 module will not work .
Axle/Gears: 9-bolt/3.45
Turned out to be simple. One side of the harness wasn't plugged into the module securely. It looked fine, but at extremely close inspection, the connector was a hair from being clicked into place, but apparently plugged-in far enough that the jiggling of the car could make the connection. Pushed it in until it clicked, and it's been fine ever since. How it came loose, I have no idea.
Doubt you'll get so lucky, but check the connectors into the module to be sure they're securely plugged-in before you start spending money and tearing things apart, especially if, for some reason, you, or someone else, has been working around that module recently, say, at the brake booster, the windshield wiper motor, etc.
Engine: 350 - 4BBL
Thanks again - Red
