Do I Have Power or Manual Mirror
Old Apr 16, 2021 | 04:42 PM
TransAm4Ever86's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 5.7 TPI
Transmission: T5 5 speed
Hi all. Been going through the Trans Am, little things like lift supports for hatch and hood, lights, etc. Since I've owned it, I've always been staring at this connector coming out the driver side door where a mirror switch would be. But, 2 dilemmas. One is its a 4 wire connector, I can't find anything anywhere with a switch having 4 wire connector. Two is the plug is sitting on a manual stick opening, like the hole as shown in the pic. I'm really not that worried about adjusting the mirrors as they are so small anyways, but would like to figure it out is possible. Thank you.
Old Apr 16, 2021 | 05:11 PM
Engine: 5.7 TPI
Re: Do I Have Power or Manual Mirror
Actually I think I solved my own issue. Mirror must have been replaced with a power mirror with wire hanging out, I believe car originally came with mechanical mirror.
Old Apr 16, 2021 | 08:53 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
If you still have the sticker with your RPO codes, you can find out what the car originally came with.
Old Apr 17, 2021 | 09:51 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Looks like the power mirror connector, but that connects to the harness, (which runs up along the top of the dash along the base of the windshield to the other mirror).The switch has a completely different connection that is hard wired to the harness.
86/305/tpi/iroc
Oct 27, 2019 07:52 PM
rickmill98
Jan 17, 2011 11:34 AM
Darkshot
Dec 14, 2006 02:02 PM
joekickass
Jun 22, 2003 08:10 AM
92blue
Jun 19, 2002 02:42 PM
