power mirrors - switch or motor?
Old Jan 14, 2011 | 04:27 PM
rickmill98's Avatar
Car: 1989 IROC Z28
Engine: 5.7L 350
Having a problem with my driver side power mirror motor. It doesn't work at all. The passenger mirror will adjust up and down but not left to right. Any help for testing the switch and motors?
Old Jan 14, 2011 | 05:16 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Re: power mirrors - switch or motor?
take the switch out and start jumping the terminals (take a small piece of wire and short the hot terminal with the others) if they start moving in the directions they dont now its the switch
Old Jan 14, 2011 | 07:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Can also check continuity between the switch and the wires at the mirror - might be a break in the wires between door switch and mirror.
Old Jan 15, 2011 | 03:41 PM
rickmill98's Avatar
Car: 1989 IROC Z28
Engine: 5.7L 350
Thanks for the info. I tried to short the Orange wire (12V+) with the other wires on the back of the switch, but couldn't get the mirrors to move. Maybe I'm not doing something correct. I read in another post that 3 wires have to be connected to get the mirror to move Orange 12V+ plus Light Green plus Yellow to get driver side mirror to move up/down. The Yellow goes to both up down motors (passenger and driver).
I checked the driver side mirror for continuity. I have continuity between the yellow wire and green wire and also between the white and blue, which is the top side by side wires on the plug and the bottom side by side wires. Does that mean the motor is still good in that mirror? I've tested 2 wire motor's that way, but have to admit I'm a little confused when it comes to 4 wires.
The passenger mirror moves up and down, but not left to right. I was also able to verify that the switch is getting 12V power. Thanks again for any assistance.
Old Jan 15, 2011 | 03:56 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Do any of u guys know if I can get power windows for my 87 camaro?thanks!
Old Jan 15, 2011 | 04:02 PM
rickmill98's Avatar
Car: 1989 IROC Z28
Engine: 5.7L 350
Are you talking about converting from manual to power windows? Or getting replacement power window motor, etc?
Old Jan 15, 2011 | 04:05 PM
calgutie's Avatar
Car: 1984 Z28
Sorry....I mean converting.
Old Jan 15, 2011 | 04:15 PM
rickmill98's Avatar
Car: 1989 IROC Z28
Engine: 5.7L 350
See this Thread https://www.thirdgen.org/forums/fabr...er-window.html
Old Jan 15, 2011 | 04:17 PM
calgutie's Avatar
Car: 1984 Z28
okay thanks but doesnt help much though...thanks tough..
Old Jan 17, 2011 | 09:58 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Mirror, Mirror, On The Car, Who Is The Fastest Driver By Far ?
That’s the wrong way to do it.
To test the motors connect:
Yellow to +, light green pin E to , then reversing polarity will produce up&down movement in the left mirror.
WHITE pin F to
+, light blue to , then reversing polarity will produce left&right movement in the left mirror.
Yellow to +, light green pin G to , then reversing polarity will produce up&down movement in the right mirror.
WHITE pin H to
+, light blue to , then reversing polarity will produce left&right movement in the right mirror.
If all the motors respond properly and you have 12 volts at the
orange wire you know the switches are the problem.
Happy Racing!
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning A Foot In The Opposite Direction?
Old Jan 17, 2011 | 10:53 AM
rickmill98's Avatar
Car: 1989 IROC Z28
Engine: 5.7L 350
Re: Mirror, Mirror, On The Car, Who Is The Fastest Driver By Far ?
Thanks NINA I will try that out.
Just to confirm, when you say reverse the polarity, I simply switch the 2 wires the other way.
SoYellow to +, light green pin E to ▬, then reverse it by connecting Yellow to - and light green (pin E) to + ???
Old Jan 17, 2011 | 11:24 AM
NINÅ's Avatar
Transmission: 765R4
Yes that’s correct.
Happy Racing!
Old Jan 17, 2011 | 11:34 AM
rickmill98's Avatar
Car: 1989 IROC Z28
Engine: 5.7L 350
I was able to follow NINA's guidance and able to get the passenger mirror to move up and down, same as was working thru the switch. The Left to Right on the Passenger and both up/down and left/right on the driver side didn't work, so it looks like those motors are out. Thanks again for your help! I'll get some replacement mirror motors and see if that doesn't fix the issue.
BRoss99
Aug 10, 2025 05:08 PM
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
stalkier
Aug 13, 2015 12:59 PM
