Will not Start
Will not Start
Good Day fellow third Gen owners
I have been having this problem for a while I will turn the key and the car will not start on and off especial after a long drive but now it will not start at all . I will have to use the remote start or start it from the starter. I am trying to figure out what's wrong with it . I replace the ignition starter relay . When I turn the ignition I will not hear the fuel pump or any of the relays but if I use the remote start you will hear the fuel pump and relay . So I am assuming no power coming from the ignition. Someone suggested it could be the neutral Safety switch my question will the car still start if the switch was bad ?
1989 Iroc z 350
Stock
Thank you in advance
1989 Iroc z 350
Stock
