Help identifying this plug
Old Jun 8, 2021 | 07:25 PM
BytePaul's Avatar
Transmission: ...was received.
I'm not sure this ever went to anything, but of course I have to be sure. I have looked around, but cannot see anything needing a plug. Any help would be appreciated.
Old Jun 8, 2021 | 07:28 PM
vorteciroc's Avatar
Top Answer: 1
Re: Help identifying this plug
What are the colors of the two Wires going into that connector?
Old Jun 8, 2021 | 07:37 PM
vorteciroc's Avatar
Top Answer: 1
It is most likely for the Secondary Air Injection Diverter Valve Solenoid...
But I can't tell what the wiring colors are; and there are two different versions of that White 2-Way sealed Metri-Pack 150 Connector (Keyed differently).
Old Jun 9, 2021 | 05:13 AM
BytePaul's Avatar
So I went a little further and took some of the wire out of the loom and I discovered that there was apparently another pair of wires of the same color. I'm not sure that black is black. It has a little pink in it, but that might have been rubbed off on it from the pink wire? So I'm guessing I had that secondary air injection at one point. The engine was rebuilt from a 350, so I'm not sure if it's a leftover from that or what. Your thoughts?
Old Jun 9, 2021 | 09:51 AM
Pink/blk is fused ignition. It goes to all manner of solenoids, sensors, etc., mostly concerned with the ECM one way or another.
The connector you have, and the other 2 wires that are cut, were probably for the AIR diverter valve, as vorteciroc suggested. Probably has nothing to do with "350" as such, but rather everything to do with how it was installed. If the AIR system is gone then that's probably what they were.
I strongly suggest you do something about the bare cut ends. Crimp a butt splice onto them, tape them up and secure them inside the harness, or something.
Old Jun 9, 2021 | 10:35 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Protecting the bare wire is a very good idea. The power for those comes from the gauges fuse. if they short out to ground you won't have functioning gauges
Old Jun 9, 2021 | 04:38 PM
BytePaul's Avatar
Can someone shed a little more light into the AIR diverter valve? Where would I find mine and would I necessarily have one installed presently? I kind of know what their function is after doing a little research, but I am no automotive expert.
Interesting that you point that out because my gauges didn't work at all. The two that are bare were taped inside the loom before I removed it, but I will definitely take care of them properly. At least I know what one reason could be for the gauges not working.
Old Jun 9, 2021 | 05:24 PM
The diverter valve would have been near the front of the pass side exh manifold. Would have been connected to the smog pump, and then hoses leading out from it went to the check valves on the manifolds, the line to the cat, and a vent.
If I were the guessing kind, I'd guess whoever put in whatever motor is in there, left all that out.
Might want to make sure there's a bolt in this hole.
If the right lower portion of your engine bay seems mysteriously bathed in an oil leak, that would be why. Install a SHORT bolt (3/8"-16 x maybe ½ - ¾") there, with a drop of sealer on the threads.
Replace the GAUGES fuse after fixing the wiring. Amazing sometimes how these things work... see my signature for a hint.
Old Jun 9, 2021 | 06:12 PM
BytePaul's Avatar
I'll be checking it the next time I look at it. Thank you!
BrandonFenrir
Mar 22, 2019 03:08 AM
evilemokid94
Jun 6, 2010 03:05 PM
DJ Delsym
Feb 8, 2009 01:08 PM
VenomX-87
May 6, 2007 03:07 AM
