Mystery Plug
Old Feb 6, 2009 | 02:52 PM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
Mystery Plug
When changing the ICM on the distributor I found a connector that is unplugged and unidentified. Here are four (4) shots of it.
Any information would greatly be appreciated.
Old Feb 6, 2009 | 03:12 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Mystery Plug
Same plug is on both my 87's and is not connected to anything, same as reported by several other members in posts here. I'm in the process of re-building the wiring harnesses on a recent motor swap and intend to trace it. Out of curiousity.
Old Feb 6, 2009 | 03:25 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Mystery Plug
what color are the wires?,jimmy
Old Feb 6, 2009 | 06:05 PM
LittleRat's Avatar
Re: Mystery Plug
On DJ's car....one is red and the other appears to be a light(ish) green. Its just hanging kinda behind the left side head and exhaust header.
Old Feb 6, 2009 | 09:18 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Mystery Plug
My '87 IROC as the same connector hanging there.
Old Feb 7, 2009 | 11:59 AM
Vader's Avatar
Re: Mystery Plug
Secondary cooling fan temperature switch?
Power steering pressure switch (A/C cutout for V6 cars)?
Old Feb 7, 2009 | 12:17 PM
naf's Avatar
naf
Re: Mystery Plug
Not A/C cutout. That connector exists on my 87 (LG4) near the gear box. Had to short it when I replaced the high pressure hose and did not re-install the switch (it was leaking). The wiring for the AC cutout connector directly breaks power to the clutch.
I know it's not part of the ECM harness either as I pulled that harness and the connector was not attached.
Old Feb 7, 2009 | 08:17 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Mystery Plug
When I borrowed a '87 Firebird service manual from the local Pontiac dealer to do some electrical system troubleshooting on a friends car I seem to remember it mentioning that was a vehicle speed sensor connector.
Old Feb 8, 2009 | 01:08 PM
LittleRat's Avatar
Re: Mystery Plug
I've also seen threads whereas this plug was used in wiring harnesses on both Camaro and Firebird, but was related to the Firebird speedometer. It doesn't seem to be an issue to be concerned with.......hopefully
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
