9 pin wiper switch??
Old Jun 14, 2021 | 08:47 PM
Terhens00's Avatar
Hello all.. Brand new here, been lurking for a while using forums for info and lessons. But this has me stumped and I can't find any help anywhere..
I've got a 1986 Camaro Z-28 Iroc
I'm chasing a wiper issue and went to replace the wiper switch. When I took the column apart I noticed I have a 9 pin connector for the wiper switch.
So started looking for a replacement and all I can find are 5 and 7 pin switches.. Am I missing something here? Why can't I find a 9 pin anywhere??
Old Jun 15, 2021 | 06:41 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: 9 pin wiper switch??
I just looked up the 86 Camaro on Rock Auto. If you get the 5 terminal you can just re-use your connector by removing the terminals from the connector with a paperclip and putting them in your old connector. Do them one at a time so you don't mix the wires up
Old Jun 16, 2021 | 10:06 AM
Terhens00's Avatar
I hadn't even thought about repinning it.. I'll give that a shot and hopefully it'll work. Thanks
Old Jun 17, 2021 | 09:02 PM
Terhens00's Avatar
Wanted to follow up and say that swapping the connector worked out. Wipers work on all speeds so I appreciate the help..
Also just thought I'd share.. I was told the 9 pin connector is from a 4th gen Camaro. So now I know someone swapped a harness in my car.
Old Jun 17, 2021 | 09:28 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I think the later cars are 9 wire too
1986_IROC-Z
Sep 11, 2018 02:29 PM
EGG
Apr 9, 2010 10:14 AM
pgtr
Dec 6, 2006 09:46 PM
jamon8
Nov 29, 2005 03:03 PM
