A/C - Heat Fan blower/motor upgrade...
Old Jun 21, 2021 | 06:01 PM
1badcj8's Avatar
Car: 89 Iroc Z G92
Engine: 5.7 HO
Axle/Gears: 3.43
My A/C Heater fan is super weak. It works, and blow a bit but even on high its weak. Is there an upgrade for it or have any of you replaced yours with a better one from a different car?
Thanks - and yes I did look through some old threads but seemed it all had to do with switches...
Old Jun 21, 2021 | 08:10 PM
vorteciroc's Avatar
Top Answer: 1
Re: A/C - Heat Fan blower/motor upgrade...
Does the Vehicle have Air-Conditioning?
If so, do you use the "MAX" setting instead of the "NORM" setting?
Have you had a look at the Blower-Motor?
There could be debris inside it, reducing performance...
or the Blower-Motor could just be tired and worn.
I do not believe there is a direct-fit "upgraded" Blower-Motor...
But something aftermarket could be made to work; or the Voltage to power the Blower-Motor could be increased.
Old Jun 28, 2021 | 10:04 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Long Winded
If you have the original evaporator its clogged with dust.
I'm not reccomending you remove it and clean it, the info is just FYI.
Servicing the evap can lead to plastic parts breaking, and insulation sealing problems.
What you can do easily is increase the wire size from its present 14 AWG to at least 10 AWG for the relay circuit.
Happy Racing!
Front Wheel Drive Is For Tricycles
89 CamaroIROCZ
Mar 28, 2019 10:43 AM
gangsta_money23
Dec 29, 2008 10:45 PM
WhiteIrocZ
Jul 18, 2006 08:27 PM
Jurrel
Apr 9, 2004 04:02 AM
85f-bird
Oct 15, 2003 12:33 PM
