Will not turn over at 200deg F
Old Jun 28, 2021 | 01:07 PM
shivey1's Avatar
Car: 1990 TRANS AM GTA
Engine: 305 HO TPI
Transmission: 5 speed Manual
Good day
I have a 1990 Trans Am GTA 5speed, 305 TPI.
The problem is after reaching operating temperature (185deg F) and turn the car off, and if the engine temperature raises at or above 200deg F the car will not turn over until the engine temperature drops below 185deg F. When I try to start the car at 200deg F the voltage gage shows 12-13 + volts until I turn the key to start and then it drops below 10 volts. At 200deg F + I can jumpstart it and or push start it with no issues (Starts right up). I replaced the battery (No change)
So before I go nuts and start replacing all kind of stuff like + and - battery cables, starter, and whatever I figured I ask if anyone has seen or had this issue.
Old Jun 28, 2021 | 02:59 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Will not turn over at 200deg F
Originally Posted by shivey1
Good day
I would suspect the starter, but before I bought one, I'd pull the old one and look it over for loose bushings/worn brushes/worn commutator, loose or corroded field windings, etc. for the 'smoking gun' indicating that it is the culprit.
Additionally, check all connections, especially grounds, for corrosion and looseness.
Old Jun 28, 2021 | 03:01 PM
vorteciroc's Avatar
Top Answer: 1
The first thing to inspect is the large Ground-Cable from the Negative-Post of the Battery to the Cylinder-Block.
If is is loose or damaged...
The Starter-Motor may not have enough Current to start the Engine.
Especially if Electric-Fans are ON at this time.
Old Jun 28, 2021 | 03:06 PM
vorteciroc's Avatar
Top Answer: 1
I have seen Vehicles crank and start with the main Ground-Cable disconnected, and the Engine completely cold.
What would happen is...
The smaller Ground-Straps would provide enough Current for the Starter to crank, with a cold Engine and minimal Electric Components on.
Good luck, hopefully it is simple to find and fix.
89_KITT
Jul 9, 2009 10:24 AM
venom204
Mar 19, 2009 08:03 PM
kbomb84rs
Aug 21, 2008 05:02 PM
Joker1232
Nov 19, 2007 12:24 PM
Mike92RS
Jun 12, 2002 03:33 PM
