Missing Portion of Wiring Harness
Old Jul 7, 2021 | 05:40 PM
Bandit_84_z28's Avatar
okay, I bought a 89 Iroc-z 5.7 TPI( engine was pulled years ago before I bough it) and was working on cleaning the engine bay for paint for the ls swap using a (Holly terminator max) and noticed I had no wiring to the wiper motor or to half of the bulkhead. any ideas on how important that part of wiring is for my application and ideas to wire wiper motor up?
Old Jul 7, 2021 | 06:11 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Missing Portion of Wiring Harness
What I can tell you is the connector in question is called the "C100" connector, and it appears your missing the engine harness side of it (The wires that are there are going to the lights, yes?). This is the 1987 C100, I'm posting it to show you roughly what's in there, your 1989 may not be exactly the same so don't take this pic as gospel, more of a reference for the diagram you need (1989 VS 1987). A search here should turn it up somewhere......
Old Jul 7, 2021 | 10:24 PM
vorteciroc's Avatar
Top Answer: 1
Most importantly...
The main Power-Distribution wires went through that C100 Bulk-Head Electrical Connector.
... this is power for the Head-Lamp Switch, Ignition-Switch, PNP/ Starter-Motor, Distributor/ Ignition-Coil, ETC...
Kind of Important!
Member: "John in RI" often has used-good Wiring-Harnesses for all different sections of the OEM Wiring for Third-Gens.
I would try and see if he has something you can use.
If not, you will have to get whatever you can find, and get help to re-Pin/ re-Terminate the C100 Connector.
I have a Thread that goes over some of the information to do so.
Old Jul 8, 2021 | 03:43 AM
Thanks guys, its a start in the right direction, ill have to try and find that member and see what he has
Old Jul 8, 2021 | 08:49 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I make new C100 harnesses for engine swap if you're interested
Old Jul 8, 2021 | 02:13 PM
I am interested, but I'm not sure what I need exactly,im looking at the diagram atm and I think all I need is A4,B4 C5 C6 C7 D5 D6(maybe)E5 F4 F7 G5 and (maybe G7 and G8)
Old Jul 8, 2021 | 02:29 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I can help you figure that out
Old Jul 8, 2021 | 02:47 PM
I'll DM you once I get home
Old Jul 17, 2021 | 11:21 AM
Surpluzz's Avatar
I need help finding one, scooter, you mentioned building one? Thanks, 1991 Z28
Old Jul 17, 2021 | 04:20 PM
@scooter is the man to go to. I'm in the process of him making me one
Old Apr 13, 2022 | 10:00 AM
z93's Avatar
z93
Car: 92 trans am
Engine: Ls 408
Transmission: 4l80
i am definitely interested in getting a harness built for the c100 can you dm me I tried to send you one but it would let me
jlpunt
Jul 17, 2021 06:34 PM
globalco
Jun 9, 2006 05:05 AM
88GTA_RebelGirl
Sep 19, 2005 02:34 AM
89ProchargedROC
Oct 23, 2001 11:58 AM
