New Starter Motor advice
Old Jul 29, 2021 | 09:37 PM
waveformkid's Avatar
Car: 1982 Pontiac Trans AM
Engine: 305 (carb)
Transmission: 3 Speed auto
I have a 1982 Trans Am. 305 with a quadrajet. I can only assume the starter is gone as it is only clicking when I try and turn over. It must be quite old as the when the starter gets hot - it wont engage or sounds sluggish but eventually starts.. What brand starter is a good option as a replacement? I am in Australia.
Many thanks.
Old Aug 5, 2021 | 11:02 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: New Starter Motor advice
Test your battery first. When you hear the clicking noise when starting, it is the starter solenoid/relay trying to transmit power to the starter motor while kicking out the bendix gear, but there is not enough amperage to keep the relay engaged so it kicks out and shuts off rapidly instead. The battery should have 12.5V or higher static charge before trying to start the car.
lb9 GTA
Jun 8, 2014 12:35 AM
iroc.86
May 26, 2008 05:36 AM
KipMaslonka
Sep 29, 2004 07:24 AM
dennis6
Sep 11, 2003 04:07 PM
f0rmula350
Apr 10, 2003 02:08 PM
