who makes a non chinese made shift light.
Old Aug 12, 2021 | 09:57 AM
aussiesteve's Avatar
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
i have bought 2 shift lights over 4,5 years and never EVER had the thing work when its supposed to,, the things are junk,, one was $60 one was $199 and both were junk.
who make a reliable unit that comes on when it should. i have $250.
Old Aug 12, 2021 | 07:36 PM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: who makes a non chinese made shift light.
No idea. I have the summit shift light, and I am sure it is a re-branded chineese version. Mine does well.
Old Aug 12, 2021 | 07:47 PM
i have one and its pretty basic...i need next kevel.as when at the strip i am not used to having to watch it while the car is doing its thing.especially wheelspin or getting it movin.i am focas on not changing lanes on gear shanges. I never see the light come on
Old Aug 12, 2021 | 09:54 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
This is what I have
https://www.summitracing.com/parts/atm-5334
I don't even use a tach, or watch it.
I program the shift light, and use it to shift at the track.
Super bright and accurate.
Been using it for 3 years now, and I bought it used.
Old Aug 12, 2021 | 10:05 PM
i got one,, problem is it got the **** at the back ,,, i cant see the stupid thing...
Old Aug 12, 2021 | 10:31 PM
vorteciroc's Avatar
Top Answer: 1
I have one with a dial at the back of the Light also...
The Engine creates enough vibration, that I had to use a small "blop" of rubber-cement, to hold the **** in place.
I have only had to raise the Shift-Light RPM once...
Peel the "blop" off, and then replace the 'blop".
Old Aug 12, 2021 | 10:37 PM
i will give it another chance,, i actually didnt see it come on at all.
nightowls_gm
Jun 14, 2008 12:52 PM
bingo
Dec 26, 2006 04:55 PM
MechCD
Jan 2, 2004 10:45 AM
84Z28_5.7ltr_V8
Oct 19, 2002 03:22 PM
IROCBandit
Feb 12, 2002 11:34 AM
