Rear lights issue
Old Aug 15, 2021 | 11:08 AM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Rear lights issue
So as I begin getting all of my wiring in order and making sure everything in the car is working properly after my ls swap, I come to checking my rear lights. Well, when I connect the water proof connector in the trunk one set of lights come on (don’t go off unless I disconnect the trunk connector or the battery). My hazard lights work in the rear as well, as they should. Now I have no brake lights or turn signals in the rear. I have checked all the fuses and none of them are burnt/broken. Any thoughts from here?
Old Aug 15, 2021 | 02:23 PM
Re: Rear lights issue
What "set of lights" comes on? There are 4. Tail, brake, turn, or backup?
Old Aug 15, 2021 | 04:27 PM
Engine: Built ls1
Axle/Gears: 3:42
For the time being I seemed to have resolved the issue. When i was reinstalling the brake light switch and inadvertently disconnected one of my power lines into the fuse block. After finding the culprit and reinserted the wire and I seem to have all my rear lights back.
NJ2FLIROC
Aug 5, 2021 08:34 AM
gta_knight
Mar 12, 2015 09:55 AM
batmanta01
Jun 5, 2002 09:35 PM
