Hatch wiring missing switch?
Old Dec 3, 2021 | 10:15 AM
adixon816's Avatar
I believe in missing the top switch in this car that activates the motor but I'm not 100% sure on that.
I have 2 wires out of the relay and black and white one with no connectors on them that go to nothing. I have an orange wire out of the pigtail that connects to nothing. That black and orange wire is for the light and I believe I have it correctly connected to the white plug. The final wire is on the passenger side of the car it has the 2 wires from the front and a black ground wire coming off that is attached to nothing.
Old Dec 4, 2021 | 12:48 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Hatch wiring missing switch?
You're in luck. I just put the 88-91 striker-sensing switch in stock on my web site. Look for part number 207180 on top-downsolutions.com.
Lon
Old Dec 4, 2021 | 05:24 PM
adixon816's Avatar
Lon
Thanks I will order one - what do I do with the leftover white and black wire out of the relay?
Old Dec 4, 2021 | 11:58 PM
lonsal's Avatar
The white wire plugs into a black with Orange stripe wire on 90-91 pull-down unit. It is a switched ground to turn on/off the rear hatch light. Earlier model years had a manual switch for the optional hatch light. In other words, for those earlier years that white wire is unused.
Lon
Old Dec 13, 2021 | 06:20 PM
adixon816's Avatar
Lon
Hey Lon I was able to get everything installed except the hatch relay. The connector under the dash doesn't match up to the relay I ordered unless I have the wrong connector. Also after installing the hatch release solenoid the key is much harder to turn - how can I remedy this?
Old Dec 13, 2021 | 09:14 PM
lonsal's Avatar
That would be because you ordered the hatch release relay (706150) instead of the hatch pull-down relay (208180). Remove and reinstall the hatch release solenoid. It must match with the release tang that opens the latch.
Lon Salgren
Top-Down Solutions
626-369-0040
Old Dec 13, 2021 | 09:21 PM
adixon816's Avatar
Lon Salgren
Top-Down Solutions
626-369-0040
Sorry should have clarified the hatch relay is good everything works with the motor I'm adding the hatch release button / relay and already installed the solenoid
Dezined
Feb 4, 2012 03:11 AM
Road Rash Ninja
Jul 15, 2010 05:13 PM
87GTAj
May 30, 2008 03:24 PM
Charlz B.
Dec 3, 2004 12:22 PM
