Need small cap distributor NOT HEI
Old Jan 22, 2022 | 06:25 PM
aussiesteve's Avatar
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
Been running a HEI pro Billet HEI and i just put a big set of taylor leads on it, 9.5mm now the boots are rubbing on the 14 inch K&N air cleaner. i am not cutting the rubber off the boots at the dizzy end or changing the boots AGAIN.
I need a small cap NON HEI ,, NON VACCUME ADVANCE, i will need a dizzy and coil.matching
Petronix has 6 i can see but whats what. not much info on their site
FAST has 2 but seems like they are for computer cars or replacement stuff,
the MSD stuff is like $550 and a coil will be $200+
I dont want chinese plug and play stuff. and require male connections on the cap end.
car is running 6300rpm and 477hp on high octane pump gas, petrol.
Old Jan 22, 2022 | 06:52 PM
vorteciroc's Avatar
Top Answer: 1
Re: Need small cap distributor NOT HEI
When I have an Engine Build where the clearance for the Distributor is an issue...
I will run a Remote Front-Mount Distributor...
or for smaller budgets; just a "Crab-Cap" Distributor (or even just the Distributor Cap and Rotor):
Old Jan 22, 2022 | 07:43 PM
Who makes a quality crab cap dizzy. I saw these years ago. A lot of the old companies are gone that made good stuff and now sell very little.
Accel. Malory,moroso,
I will be selling the car after 21 years in a few months.
Stopped pumpin money into it basicly
I can go $500 on a dissy.
cant change the air cleaner am running a holley DP and a victor junior. I need that drop down air cleaner
tonys91rs
Jan 7, 2014 09:35 AM
NBrehm
May 21, 2008 06:03 PM
1320_Guy
Mar 14, 2006 12:24 PM
84camaroZ
Jan 23, 2006 12:23 PM
jkris53406
Feb 14, 2003 12:47 AM
