Removing wires from the fuse box
Old Apr 27, 2022 | 05:03 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Let me preface this topic by stating my car sat outside, very wet, for 11 years. There is an extreme amount of corrosion in the fusebox where damp insulation collected and corroded the terminals. I did my best to scrape / blow out the insulation with everything attached, but it's obviously not a 100% fix. With the fusebox dangling, I can get the car to work when I twist it one way, and I can cut power to various systems by twisting the fusebox another way, or installing it into it's correct position.
I'd like to remove the wires one by one and clean up the connections, but I'm not sure how to get them unhooked without damaging anything. I tried prodding around the fuse side with a small screwdriver but it didn't seem like I was getting anywhere. Is there a specialty tool I can buy, or do I just need a thinner screwdriver? How are the wires hooked in?
Thanks for the help. If you've got any suggestions about a better way to restore the fusebox I'm all ears.
Old Apr 27, 2022 | 06:38 PM
vorteciroc's Avatar
Top Answer: 1
Re: Removing wires from the fuse box
Many of the Wires that enter the Bussed Electrical Center, are not individual/ separate from other Wires.
Some Wires are attached to a Bus (multiple Terminals that are attached to each other) shown below:
The Bus may have 2 or 3 or 4 Terminals...
You have to remove the entire Bus, with all the corresponding Wires attached.
Each Terminal has Locking Tangs that must be depressed to release the Bus from the back of the
Shown below:
Old Apr 27, 2022 | 07:00 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Awesome, thank you for the pictures, that helps a ton!
Old Apr 27, 2022 | 09:02 PM
vorteciroc's Avatar
Top Answer: 1
You are most welcome!
RaverRacerX
Aug 12, 2010 02:01 PM
firebirdjosh
Mar 11, 2007 04:00 PM
The Judge
Oct 11, 2002 11:16 PM
90CamaroRSGuy16
Apr 8, 2002 04:59 PM
