Fuel injector pulse
Old Apr 27, 2022 | 08:01 PM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
Fuel injector pulse
Not sure if this is the right spot for this pos
Car is a 1988 gta with a hsr set up
over the winter I moved my battery to the back of the car an made a power block for the wires that are hooked to the battery
For some reason my injectors are not pulsing I have check just about everything I can think of
i have fuel pressure I have spark I have power to the ecm I have power to every injector wire every injector ohms out at 14.8.I used a noid lite an it didn’t lite up.Now if I jump the pulse wire on the ignition module plug I hear the injector spray but when I crank the motor they will not spray injector 1 an injector 2 fuses are fine.any help will be much appropriate l..
losttheplot
Jul 17, 2014 01:25 AM
quisterio
Aug 20, 2009 07:28 AM
Black Z28
Apr 15, 2009 01:28 PM
Zap Racing
Dec 4, 2004 05:07 PM
david roush
Nov 8, 2003 10:29 PM
