Need help wiring FITech 70004 to brake switch
Old Jun 10, 2022 | 06:40 AM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Working on the wiring connections for my FITech ECU and there’s a wire that needs to have 12v when the brake is NOT applied and zero voltage when the brake IS applied. I have the factory wiring diagrams for the brake switch but not sure which wire is the right one to connect to. Would I connect this wire to the purple wire that goes to the tranny?
Old Jun 10, 2023 | 09:02 PM
battmann's Avatar
Re: Need help wiring FITech 70004 to brake switch
Just following up as I figured this out. My brake switch had two connectors on it. One controlled the brake lights and the other worked the torque converter clutch. I removed the purple wire to the tq clutch and connected this to the FITech yellow wire for the TCC brake. This provides the correct signal for the ECU. Score!
Old Jun 10, 2023 | 09:37 PM
vorteciroc's Avatar
Top Answer: 1
Yup!
That's the Brake Pedal Wire (TCC) that My Horn blown by Brake-Pedal Prank Harness uses to Honk the Horn!
Install 2 Jumper Connectors:
-One at the Brake-Pedal Switch (TCC).
-One at the Steering-Column Connector (for the Horn Wire).
And an "Aligator-Clip" to attach to anything Grounded.
With the Engine running (or Ignition-Switch "ON")...
The Horn BLOWS anytime the Brake-Pedal is pushed!!!
Old May 21, 2024 | 01:03 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Engine: 350 TPI STOCK
To clarify,
the factory purple cable is removed from the brake switch, and this purple cable is connected to the brake switch cable from the fitech ecm?,
or,
the factory purple cable is removed from the brake switch, put it aside, and connect the brake switch cable from the fitech ecm to the brake switch where the purple cable was connected?
Old May 21, 2024 | 01:51 PM
battmann's Avatar
it's the second one:
Old May 21, 2024 | 02:01 PM
wruiz's Avatar
Car: 1990 Iroc z-28
Thanks!!!!
rockit
Sep 28, 2007 01:12 AM
mars22
Nov 22, 2006 03:08 PM
f0rmula350
May 10, 2003 01:21 AM
Z89IROC
Mar 31, 2003 12:09 AM
SSC
Mar 3, 2002 02:21 PM
