Battery draining issues
Have a 86 firebird. Thought I had the battery drain fixed, HA. Wrong! Someone put in an after market radio, unhooked it. Still drained. Got a new radiator fan. Still draining. It'll last for about 2 to 3 days. Then dead as a door nail. Pulled every bulb inside, checked every fuse. New alternator, had it checked by 2 different shops. All good there. Im beyond my wits at this point! What else could be drawing the battery that fast?
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Battery draining issues
If so, and it checks out OK, get a DVOM and follow ETCG's tutorial in the vid in post #2. A systematic search, using the factory wiring diagram for your car, will turn up the problem.
