Help identifying three thick purple wires under dash (pic enclosed)
Old Jul 26, 2022 | 04:22 PM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
As above. Looks like some butchery going on here any ideas where these are supposed to go? 91 5 speed tpi trans am
Thanks!
Old Jul 26, 2022 | 04:41 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Help identifying three thick purple wires under dash (pic enclosed)
Only big and purples I know of is for crank. Powered with key in crank position? Maybe bypassed the clutch switch?
Old Jul 26, 2022 | 08:17 PM
vorteciroc's Avatar
Top Answer: 1
Correct!
I am not able to access most of my GM Data Server (I am installing a new MoBo and CPU for the next Gen EPYC).
So off the top of my head; the only 12AWG or 10 AWG Purple Wire in that area...
Would be from the IPBEC (Crank fuse) to the NS-Switch on the Clutch Pedal-Arm.
Looks like maybe an Aftermarket Spliced Circuit for Neutral Safety/ Remote Start purposes...
Old Jul 26, 2022 | 11:58 PM
GTA1990's Avatar
Car: 1991 Trans Am
Thanks and interesting. So this is different to the clutch safety switch (which works)?
Old Jul 27, 2022 | 06:05 PM
vorteciroc's Avatar
Top Answer: 1
No it is the same...
Most Automotive Parts have more than 1 correct name.
Neutral Safety Switch is a Term that can be used for a Clutch Pedal Position Switch (Manual Trans.) or a Gear Selector Park-Neutral Position Switch (Auto. Trans).
topj
Jan 29, 2021 11:11 PM
mudd746
Car Audio
Sep 21, 2014 11:08 PM
MetalGecko
Sep 3, 2008 11:34 PM
Jtufts
Jan 6, 2007 09:45 AM
kretos
Mar 14, 2004 04:30 PM
