Horn and Fuel Gauge quit working
Old Mar 20, 2023 | 12:32 AM
Roger Davis's Avatar
Car: 1991 Firebird TA, 1G2FW23F3ML202439
Engine: 5.0 TP injection
Transmission: 5 speed manual
Are these by some chance on the same circuit at the fuse box? If it's a fuse, is this all that won't work, or did I miss something else that should be not working?
The fuel gauge failed by showing FULL, when in fact it's almost completely empty. Horn just won't honk.
Old Mar 20, 2023 | 07:17 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Horn and Fuel Gauge quit working
Separate circuits. The horn goes through the C100 into the dash harness (green) and then to the relay at the convenience center. If you take the center of the steering wheel off you can see the spring contact for the horn. Its fragile, perhaps it disengaged. I would also check the relay (actually, do this first).
As for fuel, that circuit runs along the driver side door sill and through a bulkhead in between the rear seats. The wire for the gage is purple. If your fuel sending unit is original, it may be stuck and or just plain dead.
Old Mar 20, 2023 | 07:42 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
As it was said two different circuits
Ghettobird52
Jul 5, 2024 11:18 PM
Sickness91Z28
Jul 24, 2005 07:52 PM
MetalliCamaroRS
Apr 4, 2002 11:53 PM
