Very Weird Fuel Pressure Problem...wanna take it on?
Old May 8, 2005 | 12:15 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Okay
I have a fuel pressure gauge mounted in the engine compartment. Sometimes, I go out to start my car...and it won't start. I look at the gauge and it reads "0". In order to get the car running...I have the take the fuel pressure pump fuse out..and I have to start tapping the fuse to the fuse holder. It's like I have to kind of jump it by tapping the fuse to the fuse holder. Anyhow..I keep tapping it..and the fuel pressure goes right up to 40 psi and it starts fine. How weird is this? Does anyone know what it can be? Any idea's or information about this problem would be appreciated. Thanks
Old May 8, 2005 | 01:06 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Bad contact somewhere in the fuseholder. I'd cut and change it out with a new on. Try replacing the fuse first.
Old May 8, 2005 | 02:32 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
fuse
Replace both fuse & fuse holder.
Old May 8, 2005 | 04:28 PM
Engine: 5.7
replaced the fuse...next is the fuse holder. I can probably get one at Autozone..right?
Old May 8, 2005 | 05:33 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Try cleaning the corrosion off of it
Kat
Old May 8, 2005 | 09:01 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Most anywhere. It comes with about 6" of wire on each lead. if you have a multimeter or any type of continuity tester i would put the fuse in it and check for continuity. Good Luck
Old May 8, 2005 | 10:26 PM
Engine: 5.7
cool man, thanks for the help
I never said it had any corrosion on it...
thanks for the idea's everyone
Old May 18, 2005 | 09:58 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
You're right and the one in my IROC didn't look like it had any on it either.
Sorry for trying to help.
Kat
Old May 18, 2005 | 10:21 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Kat, didn't you know corrosion was self-evident everytime, all the time? Sheesh! You'd think it was some sort of chemical reaction the way you talk...
Try this next time. Before playing with the fuse, apply 12v to the 'G' terminal of the aldl and see if you then get pressure.
Old Jul 24, 2005 | 04:18 PM
Engine: 5.7
well guys....I'm still having the problem. I would think if the fuel pump was the problem...it would have went out by now....but the car starts and will run...and then sometimes..it won't. I have to keep taking the fuse in and out...until I get pressure. I do notice a clicking noise, over by the brake booster. There are 3 like boxes with alot of wires running to them. Is it possible that one of them is bad? (the one that goes to the fuel pump) What are they? Some kind of relay?
Old Jul 24, 2005 | 07:16 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Yes. Bingo. One of the 3 is your FP Relay. Cant remember which though. Someone else will chime in. If not ill find it. Try to swap them around.
Old Jul 24, 2005 | 07:52 PM
Engine: 5.7
I found which one it is. So far, it's working...I pulled the relay off, cleaned the terminals with some sandpaper, clicked it back together....maybe just a dirty terminal? We'll see...
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
