TRW Keyless Entry Blowing ACC Fuse
Old Mar 29, 2023 | 01:27 PM
BlackBerlinetta's Avatar
Car: 86 Berlinetta
I recently installed a TRW module out of a 95 Roadmaster. Locks, courtesy lights and trunk release all work with the remote. However, If I press the unlock button on either door the accessory fuse blows - the lock button seems to be OK.
This is how I have it wired up:
C2
A Nothing
B Pink (Hot in run)
C Nothing
D Nothing
E Nothing
F Black/White (Program)
G Nothing
H Nothing
C1
A Orange/Black (Hot at all times)
B Black (Trunk release)
C Tan (Unlock signal)
D Nothing
E Light Blue (Lock Signal)
F White (Courtesy lights signal)
G Nothing
H Black (Ground)
Old Mar 29, 2023 | 05:10 PM
Re: TRW Keyless Entry Blowing ACC Fuse
If that thing uses the "hot at all times" as the source that gets switched to the door locks, you're running about 30A worth of unlock solenoids through about a 5A fuse. You need to find a higher-current "hot at all times" source.
kolkane
Jan 8, 2006 02:32 AM
91_5.7_TPI
Sep 30, 2005 04:55 PM
FirebirdNYC
May 4, 2004 07:54 PM
Josh 91RS
Mar 24, 2004 10:04 AM
Camaro305to350
Aug 11, 2003 11:42 PM
